Old 03-09-2021, 10:48 PM   #1
Brad604
Originally Posted by Qingdao View Post
Partially loading the suspension would lessen the safety under the car. You are basically removing some of the force on the jackstands and making the car less stable.
Those lift points are in that place for a reason. There is a reason why professional mechanics don't lift cars by both the tires and the lift points.... just the lift points alone.
OP if the thought of jack stands toppling scares you then you can always take your jack stands and weld or bolt a big ole plate of steel to their base to increase its size and decrease the risk of it toppling over.
I did not say anything about partially loading the jack stands. Load them as usual in the usual place with 100% of the weight of the car. Then slide cribbing in a suitable place without even touching the car, come within maybe 1/2 an inch of it. It is a backup system only. If anything happens to the jack stand you are safe and alive.
2000 Boxster S
Brad604 is offline   Reply With Quote
