Old 03-08-2021, 11:06 PM   #2
Brad604
Hello. I just removed my Tiptronic on my 2000 S TODAY!! I am a pretty experienced backyard mechanic and found this job definitely a little teadius and a little tricky. I was unable to find much info online on how to do it, I mostly watched Burns's car Youtube vids for help but his was a manual not a Tip. I then followed the guide in the Bentley manual, skipping one step.
I do have a hoist in my garage, and I would have HATED this job a lot more laying on the ground. There are a lot of time consuming annoying steps to take such as:
supporting engine from above (although this can also be done from below if you want)
removing starter to get at torque converter bolts
removing cross member to get at water feed disconnects
definitely a few tricky bolts to get at
probably a few other things I am forgetting
Also that thing is not light, be careful when lowering. Attach to a trany jack, or something equivalent. I think it all comes down to your skill level and the tools you have available to decide if this is a job for you.
2000 Boxster S
Brad604 is offline   Reply With Quote
