Old 03-08-2021, 03:29 PM   #1
911monty
911monty's Avatar
Originally Posted by CharlesE View Post
'99 2.5L. The top light on the dash is always on too not sure which switch is triggering it I thought it might be for the clamshell.
Okay your car is the early model. My post above should work. These cars have switches latches and relays to make sure nothing breaks. The relay has to know where the top is before the switch will work. So briefly, clamshell fully closed depresses the switch at the motor. The top when fully closed depresses the b pillar switch. When both limits are reached the top open indication on the dash will turn off. The relay will then allow opening the top. With only the clamshell switch depressed the relay thinks the top is fully open (b pillar switch is not depressed) and will not allow further opening.
1 set parking brake.
2 close clamshell
3 depress b pillar switch. Top open light on dash should go out.
4 attempt to open top.
5 drink a cold one.
