Old 03-08-2021, 01:42 PM   #1
Kboggs
Kboggs's Avatar
Finally suffered the dread dead battery, no access to frunk issue
My 99 has levers for the frunk so thought the dead battery issue of getting to the frunk was a non issue for me, but I was wrong. There is an actuator that keeps you from popping it also. I had some extra wires handy, so this fix attached is what I did and only took me a few minutes to get access to the battery. The trick is making sure the wire makes contact to both poles of that fuse fully. At first I thought it was not going to work, but took a large screwdriver pushing in to do the trick, using the fuse did not work.
Kboggs is online now   Reply With Quote
