Old 03-07-2021, 05:29 PM   #2
blue62
Originally Posted by flmont View Post
Hello Blue62,. I used my durametric set up the enthusiast version. So then apparently I didn't have it on correct settings..?
There are no settings that can be changed in the Durametric program other then language.
Your ignition timing is described the same as my Durametric Pro. As "ms" so my guess is they assigned a time element instead of degrees to ignition timing. So "ms" would stand for milliseconds before TDC.
YOUR MAF signal is as I said kilograms per hour - weight of air over a unit of time.
Nothing you can change it is how the program is written.
