Old 02-28-2021, 09:41 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
There's another place that I have found small coolant leaks. Both radiators have a small connection for a tube at the top corner. Those tubes join and run back, under the car to the tank. The connection at the radiator is fragile and I have found them cracked on a couple radiators. Hopefully yours is good now. Have you tried a pressure test again?
