Old 02-27-2021, 10:54 AM   #1
berni29
Hi
An experienced home wrencher can remove and refit the Tip transmission. I did it last year to check the IMS. I also did a fluid change, AOS, Trans/Gearbox mounts and some brake pipes etc while I was there. Its heavy. I put mine on an engine stand, which aided getting all the fluid out etc. Follow the guides carefully and make sure you remove the converter with the gearbox.
The sump on my Tip was rusty so I needed a new one, that was the only real surprise.
Its quite a lot more work than a manual.
All the best
Berni
berni29 is offline   Reply With Quote
