Old 02-25-2021, 12:31 PM   #10
blue62
Originally Posted by ike84 View Post
Hey fan, glad to hear you're making progress. I could be wrong but I think that p1126 is a lean condition? Your negative fuel trim would support that. If you've got new injectors and good pressure then I would suspect a small leak. I know you said you smoked it but as we all know small leaks can be a pita for even the best to find.
Somebody else chime in on this, I don't wanna steer you wrong.
Sent from my POCOPHONE F1 using Tapatalk
Yes a vacuum leak of some sort has been my thought from the beginning.
Faulty injectors, Faulty O2 sensors, Or a Faulty MAF sensor can all cause a lean situation.
Porschefan has replaced or proven all those things good so I am still betting on a vacuum leak of some kind.
