Old 02-24-2021, 06:10 AM   #1
Farmlifer
Veteran & Boxster Padawan
Farmlifer's Avatar
Originally Posted by solo118 View Post
LN engineering says their IMS solution is good for about 75k (but that depends on which model you get)
I would say you can swap it out at the NEXT clutch change, considering it was just done. I can only assume you are at 50k miles, so you are good for a little while considering the IMS has only 30k on it.
However- Definitely check your oil at every oil change for metal particles.
Thanks you very much for the feedback - yes, 51K miles with clutch just replaced and will monitor oil ✅ until next clutch /IMS R&R
2003 Boxster / Speed Yellow / DRL Hack
Farmlifer is offline   Reply With Quote
