Originally Posted by The Sandman
I am curious... I have a 2001 and understand that a stalk or rocker switch is required to be installed in order to even get the temperature reading.
These are essentially momentary switches though... once I attach a switch (and have the computer activated for OBC) and advance until the temp shows, can I then remove the switch? Will the car show temp then by default next time I start or do I have to use the switch to select it with each restart?
Dave
You are correct, on the 2001 just activation of the OBC system will not result in any display; there must be either a momentary switch attached or the fourth stalk, which is nothing more than a fancy momentary switch. If you remove the switch, the display will go dark. Once the switch is installed and system activated, the display will retain the last setting on restart of the vehicle.
