Old 02-19-2021, 04:50 PM   #37
blue62
Originally Posted by ike84 View Post
Hey blue do you think a failing cat would cause his problems though? I could see that if a cat were clogged and not flowing well that would cause loss of power because of choking down flow. Would out cars attempt to lean out the mixture in order to reduce emissions if it senses a bad cat? I'm not asking to disagree, it's purely from ignorance I've not ever dealt with a bad cat before and I'm trying to piece together how that would play into what he's dealing with.
Sent from my POCOPHONE F1 using Tapatalk
1. I do not see a failing Cat causing his problems.
2.Our cars do not attempt to lean out the mixture in order to reduce emissions if they sense a bad Cat. Post Cat sensors on cars of that era do one thing = monitor Cat health via reading oxygen levels.
The only thing a narrow band O2 sensor of that era can do is sense oxygen and only in a very narrow band.
3. The reason I pointed what I see as possible failing or bad Cats is that he was talking about replacing his 02 sensors. I was pointing out that based on what I see in the O2 sensor Sine Wave, that the Sensors are fine. But the post Cat signal is suggesting a failing Cat.. So no need to replace the O2 sensors.
Ummm I think that's it Hope I answered your questions.
And there is nothing wrong with disagreeing how else could one learn he was wrong
blue62 is offline   Reply With Quote
