Originally Posted by blue62
should be a way to test all three valves you mentioned. Do a search here on the forum for EVAP system.
Should be lots of info. Evap system problems are a somewhat common issue here on the forum.
I think the tank vent valve is the one mentioned on the video that causes the hard start problem after refill.
The car is giving a code for an evap vent issue, but based on the live readings it seems to be a mechanical timing issue on bank 2 oddly enough, ill pull all 4 cams and replace the plastic guides and further diagnose.
