Old 02-14-2021, 07:18 AM   #24
ike84
If I stay with the M96 motor, then I was going to use this scoop. By what I could tell from a rough measurement it should fit without too much modification to the roof. I believe it would fit through the rear window and the intake would be just above the top of the roof. About right where the red line turns to blue in the aero pic
That should do it. I would definitely try to get the horizontal aspect of that as far forward on the roof and possible so that it's not right at the break line where air separates from the roof line. It may be worth it to place some vortex generators in front of it too to keep as much air in their line as possible. How are you gonna duct the air into the inlet from that point though? Are you gonna plumb it to the TB or just use it as a breather for your filters?
Sent from my POCOPHONE F1 using Tapatalk
