Old 02-06-2021, 06:21 AM   #5
Farmlifer
Veteran & Boxster Padawan
Farmlifer's Avatar
Now - after reading all our tips, don't stress and overthink it. Walk it through before you get the car on the trailer so everything makes sense before you're trying to figure it out with the car sitting there. It's really a simple process. I had Jon's black car on the trailer and tied down in 10 minutes tops. You might take 15 your first try.
Your F-150 will tow it easy. Get a couple miles down the road, stop and double check all your tie down points and you'll be good to go.
Then, you'll be an hour or two down the road and you'll forget you're even towing something. You'll glance in your rear view mirror and jump when you see a Boxster right on your butt!
Have a safe trip. Pictures or it didn't happen.
Thanks everyone feeling much better now about the trip!
2003 Boxster / Speed Yellow / DRL Hack
Farmlifer is offline   Reply With Quote
