Old 02-03-2021, 12:40 PM   #6
blue62
Originally Posted by kbod View Post
I watched the video Gilles sent, I learned just how sensitive these engines really are to vacuum leaks. I bought a smoke tester last night and I plan on doing a thorough smoke test right when it comes for any obvious leaks. As its always been, once I hit the gas The rpm kicks right up and it goes pretty good, not that fast admittedly but the car was never a gt3 to begin with. for the evap system there is a fuel tank vent valve (99660520301) and there is a vapor canister purge valve (99660521301) and there is also a vapor canister purge solenoid (99660520101, 99660520100)... i have no idea which one i should start with replacing
should be a way to test all three valves you mentioned. Do a search here on the forum for EVAP system.
Should be lots of info. Evap system problems are a somewhat common issue here on the forum.
I think the tank vent valve is the one mentioned on the video that causes the hard start problem after refill.
blue62 is offline   Reply With Quote
