Originally Posted by blue62
For the EVAP system from what I have seen it sounds like the purge vale has an issue.
Watch the video that Gilles mentioned in post 43 he explains what happens in that video.
How does it run at higher RPM????
I watched the video Gilles sent, I learned just how sensitive these engines really are to vacuum leaks. I bought a smoke tester last night and I plan on doing a thorough smoke test right when it comes for any obvious leaks. As its always been, once I hit the gas The rpm kicks right up and it goes pretty good, not that fast admittedly but the car was never a gt3 to begin with. for the evap system there is a fuel tank vent valve (99660520301) and there is a vapor canister purge valve (99660521301) and there is also a vapor canister purge solenoid (99660520101, 99660520100)... i have no idea which one i should start with replacing
