Old 01-31-2021, 06:48 PM   #12
dlud
Originally Posted by mforester View Post
Sorry I’m confused because you stated earlier that you had tried another set of headlights and it still wasn’t working but the issue turned out to be a wiring problem in the original set of headlights. I wonder if this used headlight I have could be the issue. Any clues as to which connection(s) could be causing all the turn signals and hazards not to work?
Sorry for the confusion. I can't answer as I don't recall switching out the headlights. Bad memory--four cars ago! I can say that the car I had a problem with had one headlight that was apparently older than the other. The internal wiring was brittle/cracked and had shorted out in a location that couldn't be readily seen.
dlud is offline   Reply With Quote
