Old 01-31-2021, 03:46 PM   #11
mforester
Originally Posted by dlud View Post
Found the problem and hazards and turns "working" again. Turns out that I still have a problem with one headlight. The wiring is in terrible shape inside the casing and it intermittently shorts out and then blows the fuse(s). So my plan is to replace the wiring. Anyone rewired a headlight? Some of the wires, particularly that run to the turn signals, are not easy to access. May have to get creative.
Sorry I’m confused because you stated earlier that you had tried another set of headlights and it still wasn’t working but the issue turned out to be a wiring problem in the original set of headlights. I wonder if this used headlight I have could be the issue. Any clues as to which connection(s) could be causing all the turn signals and hazards not to work?
mforester is offline   Reply With Quote
