Old 01-31-2021, 02:10 PM   #10
ike84
Those relays run straight back to the ecu. Did you have the battery disconnected while working on the pins? I understand the reason for testing the pins to confirm their function but it's quite risky doing any kind of work like this with the battery connected.
Check your wiring harness, something may have been dislodged. Otherwise you may have a big problem..
Sent from my POCOPHONE F1 using Tapatalk
