Old 01-31-2021, 04:03 AM   #10
ike84
I probably did take those off as they're right next to my exhaust now. I'm going to seal them off with some sheet aluminum and raise the front of my trunk a little higher. If you ever look at your car after it's driven in the rain, you'll see the air coming off the side of the B pillar swings back towards the center of the trunk creating a slight higher air pressure right where the raised portion of the trunk would be. In theory, making a great location for a scoop.
Did you do anything to seal the ecu from dirt and water?
Sent from my POCOPHONE F1 using Tapatalk
