Old 01-30-2021, 08:05 AM   #1
obthomas
FS 996 cluster for 986 2002 to 2004
I just finished the 996 to boxster cluster upgrade. Along the way I have an extra 996 cluster for a manual transmission. It is all black 5 gauges with OBC activated. The cluster is coded for cruise control and is coded for the right fuel reading. The cluster is coded to indicate roof position. The cluster has green, blue and grey connectors and should fit a manual boxster 2002 to 2004. I can further code it with your VIN and any mileage you want. All you would need to do is install it, add a wire from the green connector pin 5 to a new sender replacing your oil pressure alarm, about $50. You would need to dremel your cluster cover for the two new gauges. If you have been hesitant to do this mod because of the minefield in acquiring a suitable 996 cluster, this will help you with that. I will take $300 for this cluster. If interested or if you have any questions PM me
obthomas is online now   Reply With Quote
