Chatting with a few other track buddies, they seemed to think that the Delvac might not be very good at handling high heat, and recommended either Motul or Redline gear oil. I don't mind changing the oil again as it's pretty easy, but I'm trying to make sure I understand why the oil would cause one gear to not want to engage. It was obviously related to RPM/heat and started working again as soon as the engine cooled a bit (literally right after 1 cool down lap, 2nd worked again fine) so I guess oil temperature could make sense?
