Old 01-26-2021, 04:50 PM   #11
Qingdao
Qingdao's Avatar
Originally Posted by losblancos View Post
That’s the thing... I don’t need it to be perfect, just not glaringly obvious.
(It’s done living in the South so I’m not as concerned about future damage and I got it cheap. It’s a driver, never going to be a concours car and I’m fine with that.)
Then you can sand off the clear and re-clear it.
If it were me I'd sand the clear completely off the affected panel. Then dust on a coat of base. Then clear as normal.
Problem here is that this is a pretty advanced technique. Not a first time DIY thing. If you do take it to a professional shop they are probably going to advise a complete re-spray of the car; I mean the clear is thin here it is probably thin on the whole car. You might be able to find an independent to re-clear it for you.
'98 PP13B powered "RX986"
