Old 01-25-2021, 10:20 PM   #6
puravidabahia
For the re-start trouble, look into "Evap Purge Valve". It's a valve under the left side intake. Here's an article on the basics (not Porsche, but similar): https://www.samarins.com/glossary/purge-valve.html
It may not be the cause of the P1128/1130, but it is likely still part of the problem.
Here's one discussion here: Success! Finally fixed the hard start while hot and fueling issues.
thanks!.....that "hart start" post sounds like the cure......much appreciated!
i'll update once i've tried that
puravidabahia is offline   Reply With Quote
