Old 01-25-2021, 07:50 AM   #6150
ike84
My build thread is posted over in the DIY section. I doubt that a 74mm TB will bolt on to a 3.2 but it wouldn't be that difficult to do so (74mm = 3" which is what the stock intake pipes should be). If you do that though I would remove the spec airbox and fab a new CAI, the boxes on our system are very restrictive. As long as you don't change the MAF housing size you can do this without making any ECU upgrades, although a tune will be of help to get the most out of it. You can find a ton of info about this stuff on here.
