Old 01-20-2021, 03:32 PM   #3
Dllrd23
From what I see and hear in the video it is firing up just not staying running.
Possible fueling problem.
I would check the fuel pressure at the fuel rail. there is a pressure spec. for key on not running and key on running. See if you fuel pressure at the fuel rail meets spec.
That is what I would check first.
If fuel checks out then it could be the immobilizer overriding starting.
The O2 sensors are not active at cold start. so they are not the problem.
Blue62 is spot on about the o2 sensors and I also agree about the fuel pressure. I would also add to check injector pulse. Interested to see what it is doing when the thing dies. I suspect you have pulse initially but immobilizer could be cutting either injector pulse or fuel pump power so watch both at the moment it stalls.
Dllrd23 is offline   Reply With Quote
