Old 01-15-2021, 01:42 AM   #2
CrisZenithBlue
CrisZenithBlue's Avatar
Originally Posted by Radman View Post
I had glasses hanging from shirt, under the seatbelt. Took the seatbelt off and then heard my glasses merrily clanking their way down into somewhere.
The top is up. Unsure of what my next steps should be lol!
Any experience or ideas?
Thanks!
guessing you checked behind and under the seat.
they could have fallen behind your left shoulder in the space where the top transmission sits and moves around. if you tilt your driver's seat forward you should be able to stick your head in there and see better. alternatively, move the top down just a bit, as putting it in the "service" position, just as far as the clamshell goes up and out of the way, then you can poke around in there from the outside (you can move those black plastic covers attached to the clamshell, banana shaped, to see better). be careful with this move, maybe move the top slowly and check often as there are 2 rods spinning on the top transmission in that space and if your glasses are in there, at the lower spot, they could be crushed.
CrisZenithBlue is offline   Reply With Quote
