Old 01-13-2021, 05:40 PM   #1
mtb50
Originally Posted by Qmulus View Post
FWIW, I have repaired a couple of them, and also salvaged the "programming" from an otherwise unrepairable M535 module and transferred it to another good used one with an identical part number. No reprogramming was needed, other than to clear the fault codes that were stored in the module as it was failing. The data that you need is not in the processor, but rather stored in a separate IC. So in my experience, there is never a reason to have to replace everything.
This should be more than enough information for someone with a bit of an electronics background. Sorry, that is about all the info that I will share, as this kind of work is part of my business...
I am in need of having my immobilizer repaired. 2000 boxster Car starts and runs OK, convertible top is OK my windows do nothing.
mtb50 is offline   Reply With Quote
