Thread: 2.7 swap
Old 01-12-2021, 05:56 PM   #7
Dllrd23
Originally Posted by truegearhead View Post
Thanks for reaching out over IM. As you know I put a 2.7l in my 2.5l car. You need to use the 2.7 intake manifold, and the 2.5l crossover and throttle body and the 2.5l wiring harness. The vacuum port for the second cross over can just be blocked. I used the factory 2.5l ecu. It dyno’ed at more power to the wheels then a 2.7 is supposed to make at the crank and ran great. If you need anymore help let me know, happy to help
Edit: I also used fuel rail and return system from the 2.5
Injectors from the 2.5 or 2.7 or are they the same?
Dllrd23 is online now   Reply With Quote
