Thread: 2.7 swap
Old 01-12-2021, 04:47 PM   #1
truegearhead
truegearhead's Avatar
Thanks for reaching out over IM. As you know I put a 2.7l in my 2.5l car. You need to use the 2.7 intake manifold, and the 2.5l crossover and throttle body and the 2.5l wiring harness. The vacuum port for the second cross over can just be blocked. I used the factory 2.5l ecu. It dyno’ed at more power to the wheels then a 2.7 is supposed to make at the crank and ran great. If you need anymore help let me know, happy to help
Edit: I also used fuel rail and return system from the 2.5
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
