Originally Posted by 78F350
That same connection that goes to the top relay from the switch also connects to the CLU connector 1, pin 18. You can check it for continuity and/or +12v. Once you have done that advance to the next question.
The top relay diagram:
Where it goes on the top relay plug:
To the CLU...
what it look like on the CLU plug:
I had the seat out today and the fuse is ok. tomorrow I'll do what you showed here and get back to you. Thanks
