The top relay is indeed not a typical relay. There is quite a complex circuit board in there that does a lot of figuring to operate the top based on a bunch of inputs. A new replacement will set you back a couple of hundred bucks but I obtained a used one from ‘itsnotanova’ to do the hack that allows you to operate while moving and not engaging the parking brake. He charged me $35.00 which was a bargain as far as I’m concerned. I got it because I wanted to keep my original relay unmodified so I could put it back should I want to return the car to stock.
PS I see you are in Texas. So is ‘itsnotanova’ Reach out to him and see if he has any more relays from the multitude of Boxster he has dismantled. I would let you try my spare but I’m about 1,400 miles and another country away from you.
