Old 01-10-2021, 05:38 AM   #10
mtb50
It`s a double relay, I don`t think you can find a generic automotive relay that will be the same. A typical issue is related to the parking brake warning light switch, if that does not work, it will not tell the relay that the parking brake is on, and the top won`t work. Is the parking brake warning light on on the dashboard when you operate the parking brake?
Parking brake switch is ok because the top will go and down. This is good to mention this for those out there having problems with the top. Thanks
mtb50 is offline   Reply With Quote
