Old 01-09-2021, 01:56 PM   #1
Qingdao
Qingdao's Avatar
1k mile update
So after 1000 miles I think this machine is about in its final form.
I ditched the hot air intake and made this cold ram air intake. I blocked off the original hole and made my own in where the top would normally sit. In theory this should shoot cold air from the side intake into the conic filter that feeds the carb. In reality it makes cool intake noises from the side of the car.
My fear of a VERY unbalanced plenum is put at ease a little bit by making this "gutter" to feed cylinder #6. Its just a piece of steel in a gutter shape that is bolted to the intake; then the piece is welded to the bolt. All the parts are larger than the intake runners so I'm not afraid it will get sucked into the engine. But it should help charge #6 as much as 1-5.
And lastly I finalized my A/C situation. I just jumped strait off the A/C cycling switch to a toggle switch to power my A/C compressor. I have a toggle switch to turn my A/C on; not too happy about that. BUT it works and cycles under pressure changes, and the HVAC works just as stock otherwise.
And after driving for a while now I can say its a hoot. Yall already know how spectacular the handling is, and the creature comforts are just as amazing as I remembered them to be. The car is not as powerful as I'd wanted, but much more than a stock boxster. Butt dyno measures 300hp at the wheels. More than a boxster S; which is plenty. If I really want more I can always put a shot of giggle gas on there; lord knows the IRON block will take it with stride.
'98 PP13B powered "RX986"
Qingdao is offline   Reply With Quote
