Old 01-09-2021, 12:04 AM   #1
husker boxster
husker boxster's Avatar
Try Dr Colorchip
+1 on the Dr Colorchip.
However, I never have any luck with their procedure of paint & dab it smooth. But this works for me:
1. If you have wax on the area, use some bug & tar remover to cut the wax, then wash it off for a pristine surface. Let it dry before step 2.
2. Fully fill the chip with paint. Don't worry if you have a blob. Let it fully dry hard.
3. Take some 1500 wet sand paper and carefully smooth out the area. No need to make it a large area where you sand, just focus on the chip / blob.
4. Once the chip is blended in, hand apply rubbing compound on the area to begin to eliminate the sanding marks.
5. With a polisher, continue the restoration with swirl remover (it's a mild rubbing compound), then polisher, then wax.
Try it in a low visibility area first to perfect your skilz. It takes the nerves of a cat burglar when doing the sanding. Remember, if you don't go far enough you can always do more sanding. The reverse is not true.
1989 928 S4 5 spd - black
