Thread: IMS center bolt
Old 01-08-2021, 01:35 PM   #3
Homeoboxter
I hear ya. The "leak", as you call it, would drip back into the sump. It's the same as all the other oil passages.
Everyone has their own comfort level, and you're certainly not wrong.
I meant a leak causing a drop in the oil pressure. An engine oil circulation system is designed such that the oil pump is able to compensate for the oil loss at the bearing/bearing journal clearances. The pump`s capacity is calculated by the engineers such that it can keep up in all circumstances, high temperature, low rpm, low viscosity, partially worn bearings, etc. Here comes the user, and hits a hole with a mallet right into the heart of this delicate system. Most likely the loss is negligible and won`t cause oil starving, still, it sounds super sloppy and unprofessional to me. But it`s just my thinking, it`s totally fine if someone is ok with it
Homeoboxter is online now   Reply With Quote
