Thread: IMS center bolt
Old 01-08-2021, 09:46 AM   #17
JFP in PA
But for this reason I added a "drain hole" to the IMS where the trapped oil can escape.
A better and permanent fix would have been to install a plug behind the bearing, as is done in all IMS Solution retrofits. The IMS shaft tube is weak enough without drilling drain holes into it.
