Thread: New member
Old 01-07-2021, 07:13 PM   #2
mtb50
Looking over the wiring diagram, it looks like power for the window motor is supplied through fuse D1. From there it goes to the door harness(s) to an electronic module in the window motor.
The power for control through the window switches is on the middle connector of the three. It looks like that voltage is sourced through the relay for the convertible top. I have power on that middle connector with the key on or off.
*This information is free and may be completely wrong (at no additional charge).
I thought it might be the relay. Do you know if there's a way to check the relay? Thanks
mtb50 is offline   Reply With Quote
