Thread: IMS center bolt
Old 01-07-2021, 05:43 AM   #17
elgyqc
elgyqc's Avatar
Originally Posted by WhiteyII View Post
I went in to my 23,250 mile 1998 Box and as the pictures show the dual row bearing was on its way. I pulled the seal on the bearing and found the bearing cage was broken but still in place and the balls just starting to go but races looked good...
I know I'll be flamed, but I think I'm going to put it back together. I ordered a LN spin on filter and mag drain plug. I have a filter cutter so I'll change the oil at 50 miles first and inspect the filter, then 500 and then 1000mi. Your thoughts........
Very interesting. Seems to be the perfect example of IMSB failure in a car that has not been driven enough. I inspected the IMSB on a 2000 Boxster with 115,000 miles on it, I pulled the outer seal and verified the bearing, it was fine. I put a new o-ring on the flange and put it back on, it has been running ever since without problems.
Was there any grease left in the bearing... or oil?
I find your course of action reasonable. With the bearing seals in place it seems to me that very little metal would be circulating.
Grant
