Thread: New member
Old 01-07-2021, 04:47 AM   #4
piper6909
piper6909's Avatar
Originally Posted by mtb50 View Post
I've received a lot of info on this forum and many thanks. I have a 2000 boxster 79k miles that needs a lot of TLC. I've replaced motor mount, convertible top transmission gears and top at some point etc. Both drive and passenger windows do nothing. I connected a hot wire to the window switch to check motors and they are both OK. With a test light I do not have a hot wire at the window switch plug should I and if so what does this connect to.
Welcome to the forum. Do the windows drop down a few inches when you open the latch for the convertible top? If so, you don't have a problem with the motor, wiring or switches. You may have a problem with the immobilizer under the driver's seat.
2010 Subaru Forester
