Thread: IMS center bolt
Old 01-06-2021, 05:47 PM   #7
WhiteyII
I went in to my 23,250 mile 1998 Box and as the pictures show the dual row bearing was on its way. I pulled the seal on the bearing and found the bearing cage was broken but still in place and the balls just starting to go but races looked good.......there was surprisingly very little metal. When I pulled the bearing there was some in the tube but again very little, used paper towels on a set of magic fingers first with diesel fuel on the towel, I have a borescope and there is now nothing in the tube. I pulled the filter and it was spotless, dropped the oil and pan also spotless. The oil and filter had 500 miles. bought the car with 9100 miles in 2017. the oils been changed 4 times since I've had it with one being at the PDI. every filter has been cut and inspected with each. Did a 5000 mile cross country trip last July and changed the oil before I left and when I got home and inspected that filter as well, all have been spotless.
I know I'll be flamed, but I think I'm going to put it back together. I ordered a LN spin on filter and mag drain plug. I have a filter cutter so I'll change the oil at 50 miles first and inspect the filter, then 500 and then 1000mi. Your thoughts........
Dave
1998 Boxster
1978 R100RS BMW Motorcycle 140K, 1 owner
WhiteyII is offline   Reply With Quote
