Old 01-06-2021, 11:56 AM   #1
donk
'06 987 Convertible Parts
Hello 986 forum. I posted this over on the pelican boxster board but hoping there might be someone here with insights that isn't on that board. Also hoping it's ok to post 987 questions on the 986 board.
Anyway, I recently purchased a 2006 Boxster. Somewhere along the line, most of the convertible top mechanism was removed. It works fine manually but I would like to get it working again the way it should. The only thing left is the motor, which works when connected to 12v, but not via the switch. Need to track down why that is, maybe just a fuse or microswitch. The mechanism is missing cables, transmissions, and linkages.
It seems there was a bit of a design change sometime during the 06 model year so I want to make sure I'm getting the appropriate parts. Mine is an early '06 model. It looks like the transmissions (and maybe some of the linkage pieces) are the same as the ones from the 986 Boxster (based on searching these parts on Pelican), but I'm having trouble verifying that b/c of different or superceded part numbers. Does anyone know which of these parts, if any, are the same that were used for the 986? My objective is to source these parts used, so knowing which year models to include in my search params will be super-helpful. There are a ton more used 986 parts than 987, especially since it seems like I can only look at 987 parts up to the mid '06 change. Anyway, if anyone can help, it would certainly be appreciated.
donk is offline   Reply With Quote
