Originally Posted by amagalla
I've done the drive cycle many, many times. Still no luck. I did at one time get a 0446 code, but I changed the valve under the intake and cleared the code and haven't gotten it again. But, I still have the jug noise, and it still can't get to ready state for the smog test.
As I say: if you're doing the drive cycle, it does the self tests and either passes or fails, going into ready mode or popping a code (not always a cel)
If neither are happening then you're either doing the drive cycle incompletely, or you have a problem with the computer.
What drive cycle steps are you taking? What does your drive cycle process look like?
