Old 01-03-2021, 02:41 PM   #10
djw8282
djw8282's Avatar
Originally Posted by 10/10ths View Post
....you will just lose power.
The stiffer motor mounts trigger the knock sensors and the engine management will retard ignition timing to prevent what it thinks is detonation.
I’ve seen dyno tests to prove it.
I promise you that every Porsche out there with inserts or polyurethane bushings in their motor mounts now own slower cars.
So if you want more noise/vibration/harshness AND a slower car, by all means, send your hard earned money to the aftermarket purveyors who feast on all of the uninformed new Porsche owners who are now buying these old cars because they have depreciated to the point where they are cheaper than new Corollas.
You have been warned.
Just don’t do it.
Cheers.
Hey 10/10ths.
I will be pulling my Powerflex engine mount. The vibration is too harsh coming from this area. Question for you. When you say lost of power from engine mounts, are you saying Transmission mounts as well?? I have Rennline trans mounts and I'm not sure if I want to pull those as well.
By the way I have a Durametric. I didn't see any underlying codes. Maybe someone can direct me what to look for if theres a knock sensor issue. Thanks.
djw8282 is offline   Reply With Quote
