Old 01-02-2021, 02:49 PM   #1
KevinH1990
KevinH1990's Avatar
I suggest that you compare your work to this photo on the Pelican web site: https://cdn4.pelicanparts.com/techarticles/Boxster_Tech/69-BODY-Hardtop_Installation/images_small/Pic2.jpg
If it is identical, then you may have another problem. For example, is it possible that you over-tightened the shoulder bolt that holds the insert in place? That might cause the shape to distort and make it difficult for the lock to turn.
