You say after all you've done that it won't go into ready mode? What have you DONE to get it into ready mode?
I mean, have you performed the OBD drive cycle for the car at least 3 times?
If you have, and it still won't go into ready mode, but isn't popping codes, well then you've got a different problem.
If you've got a system failing, it will pop a code. No codes=no failing systems.
