Thread: Problem!
Old 01-01-2021, 06:53 PM   #19
evomind
Thanks guys
I looked from top to bottom with a flashlight.
The part Im showing is the only place I found anything leaking. If you look there isnt any drip or leak above that gasket and I found a drop hanging off of it.
I *assumed* it was antifreeze because the smoke was white and kinda smelled like antifreeze.
I believe the smoke was coming off the header rather than out the exhaust.
Im going to get it on a lift for a closer inspection this weekend.
Assuming thats where the leak is coming from, is that just a gasket issue or what? The metal looks pretty jagged there.
2001 Boxster S in Tucson, Arizona
evomind is offline   Reply With Quote
