Old 01-01-2021, 05:28 PM   #11
dghii
Your car looks great, congratulations!
Do your maintenance but don't forget to just drive it and get to know what you've got.
As for oil filter maintenance, if you don't go with the LN right away, get the OEM oil filter housing and filter so the filter bypass spring will be replaced. The entire housing and filter isn't much $...under $30 if IIRC.
Suspension and brake items you mentioned are easy and inexpensive to replace and will make a world of difference in the noises you're experiencing.
Enjoy!
dghii is online now   Reply With Quote
