Thread: Problem!
Old 01-01-2021, 04:21 PM   #18
78F350
Motorist & Coffee Drinker
78F350's Avatar
Evomind if you clean everything very well with Simply Green and rinse it afterwards with "low pressure" water you should see where the oil is coming from.
+1
The low coolant that you originally had is possibly an unrelated issue. What I see in the picture is an oil leak onto the exhaust, which will cause smoke.
Took the car for a drive today and sure enough it smokes.
Is the smoke coming out of the exhaust tip or is it the leaked oil burning?
I often use my cell phone camera to reach in and get pictures of areas that I can't quite get a view of. Try getting a picture of the engine area above where you are currently showing the leak. In some cases video works better. It may be bad spark plug tube(s) causing the oil leak.
