Old 01-01-2021, 11:41 AM   #6
A8ked
A8ked's Avatar
If the tank is yellow in color instead of almost white, it's old and likely to fail in the foreseeable future.
When they fail its usually sudden and there will usually be coolant on the trunk floor and dripping from the forward passenger side wheel well area. If you pull out the trunk carpet and remove the panels on the floor you can check for any leakage.
Mine would leak when the coolant got up to temperature and the tank expanded, opening a crack in its bottom. I could not see the crack from above, but the coolant was all over the trunk bottom.
1998 Boxster
1991 Carrera
A8ked is offline   Reply With Quote
